parking brake issues
Old 03-24-2014, 03:02 PM
Thager's Avatar
Thager is on a distinguished road
Default parking brake issues
i have a 2000 with disk brakes and the parking brake inside the drum , has anyone had problems with the brake actuator, i can push the p-brake pedal to the floor and nothing happens, the cable is tight at the wheel but the shoes dont move.
Old 03-25-2014, 06:08 PM
okiedoak20's Avatar
I have had issues with the parking brake as well...
I ended up.replacing the parking brake pads and the hardware
thats operates it...I would recomend the kit from Rockauto
that has all hardware included . Including the rubber boots
That fit around the actuator arm....use grease inside the adjuster cups
And I needed to clean the lip of the rotor so the parking brake pads
Would not excessevly drag when installing the rotor onto
The brake assy..you mat also need to loosen the parking brake cable to
Adjust the parking brake shoe properly...also i found that
Adjusting the parking brake is a little tricky...there are three points of adjustment
An adjuster on each wheel, then the cable adjuster on the
Driver side along the frame rail....look at how it works ..when
The parking brake pedal is pressed only one side is adjustable then to adjust
The other side its done with the star adjuster in the wheel...
Sorry for the long reply...but it took me a little while to figure
It out...
Old 03-25-2014, 07:08 PM
Thager's Avatar
thanks ill check it out next time i have it apart
xderkax
01-14-2010 11:38 PM
SlimshagE
03-24-2007 10:24 PM
ctstar2000
03-15-2007 09:31 AM
blackknight
02-08-2007 03:27 AM
J2K
05-29-2006 10:50 AM
Quick Reply: parking brake issues
