Passenger front kick panel
Old Mar 5, 2017 | 06:50 PM
iceblue068's Avatar
iceblue068 is on a distinguished road
Default Passenger front kick panel
I have noticed that when I go through a car wash ,water gets in down and under my passenger side kick panel. Can anyone tell me where this leak may be starting from?
Old Mar 5, 2017 | 07:05 PM
sounds like it's coming through the antenna grommet hole; common...
easy fix with some clear silicone
Old Mar 5, 2017 | 07:14 PM
iceblue068's Avatar
I think it's more towards the bottom of the windshield rather than the antenna because there's no opening around the antenna and the water rushes in rather than a trickle
Old Mar 5, 2017 | 07:20 PM
iceblue068's Avatar
Old Mar 5, 2017 | 07:32 PM
not the antenna itself, the grommet where the wire for the antenna passes through the firewall
mine became a leaker after running another wire through the grommet... most start leaking after just being bumped when working around the area...
Easiest check is to reach under the passenger side of the dash just under the glove box and pull the carpet back and away from the firewall. Pop the hood and take a hose and spray a little just to the right of the AC evap box (don't worry, you'll not going to harm anything by doing so...). Then poke your head inside and take a look at the grommet with the back wire passing through it. I'll be obvious if it's leaking there...
Old Mar 5, 2017 | 07:36 PM
iceblue068's Avatar
okay thanks,makes good sense,sorry for my misunderstanding
Old Mar 6, 2017 | 10:19 AM
Tajohns34's Avatar
I had a similar problem with water. It went away when I replaced the door pins on my passenger side. I guess the door was sagging enough that it wasn't sealing and it came in under the kick panel.
Old Mar 6, 2017 | 12:33 PM
that's super common on the driver's side since that door gets used the most, but it does happen on the passenger side as well. usually then it'll drip in and onto the door panel around the power window switches and ruin them...
WalkGood
Sep 23, 2013 12:17 AM
tdbone1
Dec 4, 2012 07:44 AM
9402blazerky
Apr 4, 2011 11:46 AM
CustomBlazer0047
Jun 26, 2010 05:33 PM
JediKnight2
Apr 11, 2008 01:55 PM
