Passlock
Old Apr 13, 2010 | 09:02 PM
reytx1's Avatar
reytx1 is on a distinguished road
Default Passlock
After fixing a short in my multi-function switch wires (as seen in this link: https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/headlight-short-43213/ ) My blazer will not stay on!
When I try to start it, it quickly dies out after a quick second.
My security light IS on so I think its the passlock system but it doesnt make since because it does turn on for a little while. I started it with starting fluid and it kept it on for like 5 seconds then it died again.
I have fuel, and i obviously have spark since it turns on.
any idea what it might be?
Oh and I tried to reset the passlock but when i leave it on the on position for ten minutes after trying to crank it, the light still wont go away. And I know your suppose to do it 3 times but from the write up I read the light itself is suppose to turn of after the first time, but mine doesnt. Could anyone relate to my problem? Or maybe help me out to find out what is wrong?
Thanks in advance.
EDIT: I forgot to mention that usually when the truck sits for two or more days it has trouble turning on. It sat for two days but from the previous times it happened before, i dont recall seeing the security light as I do now.
Old Apr 14, 2010 | 05:59 PM
reytx1's Avatar
UPDATE: Today I just checked the fuel pressure and I was reading 60 PSI which is good, So i'm guessing it has to be the passlock but I thought if it was the passlock system then it would not let it turn on at all. My truck turns on for about a second then dies out.
Old Apr 14, 2010 | 06:41 PM
Definitely sounds like a passlock problem. Even when the pass lock system locks you out, the engine will fire and run for a bit before shutting down.
Old Apr 14, 2010 | 07:05 PM
reytx1's Avatar
hmmm I figured there was something else wrong because on the article you wrote it mentioned it will not turn on, I'm gonna try the the passlock re-learn procedure again.
Thanks for the feedback
Old Apr 14, 2010 | 07:31 PM
reytx1's Avatar
Ok swarlkk, i'm trying to reprogram the passlock system but i'm a little confused on your write-up https://blazerforum.com/forum/showth...light=passlock after you turn the engine on you leave it on the on position UNTIL the security light comes off right? And it should only take around 10 minutes. Mine has been on the on position for 20 and my security light is still on.
Am I doing something wrong?
Old Apr 14, 2010 | 07:33 PM
If the light is staying on, then you may not be able to do the passlock self learn and may have to get it done at the dealership.
Old Apr 14, 2010 | 07:36 PM
reytx1's Avatar
I was really hoping not to do that but i guess it happens sometimes.
Anyone have any idea how much the price ranges from to get it reset?
thanks swartlkk
Old Apr 14, 2010 | 07:40 PM
Probably a flat hour charge. The cost depends on the hourly rate of the dealership.
Old May 10, 2010 | 07:01 PM
ortizsrh's Avatar
ortizsrh is on a distinguished road
i have 2000 blazer and i put a remote start alarm in it but the remote start will not work it keeps dieing out. any ideas. it starts with the key. thanks
Old May 10, 2010 | 08:14 PM
If you didn't install a passlock bypass module and properly programmed it, your RS unit doesn't have a prayer of keeping the engine running.
