are the pcm (computer) the same in a 96 and 98 blazer/jimmy
Old Aug 23, 2009 | 03:21 PM
cartunez2004's Avatar
cartunez2004 is on a distinguished road
Default are the pcm (computer) the same in a 96 and 98 blazer/jimmy
i have a 98 gmc jimmy and was told that the computer is bad (trans issue) i have a 96 blazer parts truck, are the computers the same need help quick thanks in advance
Old Aug 23, 2009 | 03:35 PM
Short Answer: No, it is not a direct swap.
Long Answer: In terms of their physical make up, they are pretty damn close to each other and should be able to be swapped. The problem: incompatibility in the form of the programming. You may be able to have the dealer reprogram it to your VIN though.
Old Aug 23, 2009 | 04:27 PM
i heard from a few people u can thats y im askin
Old Aug 23, 2009 | 05:56 PM
Programming will be different. One easy difference is the 96 truck has 4 O2 sensors and the 98+ have only 3. The PCM will be looking for the pre-cat O2 sensor that the 96 has and will not see it because your 98 has no such sensor.
At the very least you would have to get the PCM reprogrammed for your truck, most likely by a dealer to the tune of at least one shop hour. I believe that another member had his PCM reprogrammed by the dealer recently costing around $100 and that was just to add RKE (remote keyless entry).
Old Aug 24, 2009 | 02:12 AM
rjohnson2's Avatar
rjohnson2 is on a distinguished road
could i pick up a pcm from any 98-04 blazer and send it to one of the custom tuning places and it would work in my 2000 blazer?
Old Aug 24, 2009 | 06:35 AM
RonJon's Avatar
RonJon is an unknown quantity at this point
I rather doubt it. They'll change fuel curves, timing curves, etc., things affecting performance. But I rather doubt they can add production options. Examples: my blazer doesn't have fog lamps and I'd like to add 'em (factory that is). A bit of wiring, a headlight switch, it seems simple..... except I'd have to have the dealer add the option to my computer. Ditto for the tow/haul option, the wiring is all there, just add a push button switch, but the RPO needs to be added to the computer (this I tried) <grin>.
kmartin
16
Jan 2, 2023 09:06 AM
abig84
Jan 5, 2012 08:23 PM
mikepro
Aug 15, 2011 07:03 PM
AmberRose
Aug 30, 2010 08:58 PM
cartunez2004
Oct 23, 2009 04:21 PM
