PCV valve heard in cabin
Old Dec 25, 2007 | 02:24 PM
jcheil's Avatar
jcheil is an unknown quantity at this point
Default RE: PCV valve heard in cabin
I have a related question:
There is thehose that goes from the top of the PCV valve to the throttle body. If I disconnect it at the PCV end or at the Throttle Body end, I do not feel any vacuum. Is this normal?
Thanks.
Old Dec 25, 2007 | 02:59 PM
blazinloud's Avatar
ORIGINAL: lastcoupe
I have seen this problem on many of the 2001-ish model year blazers, It's somewhat normal for it to make the noise, but the reason it is transmitting the noise to the passenger compartment is because the throttle cable is contacting the PCV hose. Get a zip-tie and secure the cable away from the PCV hose and it will solve the problem.
Bingo! mine did the same thing so I used a peice of plastic from my 6 pack
Old Dec 25, 2007 | 03:58 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
ORIGINAL: jcheil
Thanks.
If the engine is running then I do not believe this is normal. I am not sure what the amount of vaccum that should be there is but I know there should be some.
89Recon
Oct 22, 2011 05:50 PM
dimmuborgir6nik6
Oct 10, 2008 10:34 AM
ricwin
Sep 30, 2008 09:56 PM
gscrippler
May 4, 2008 07:42 PM
blazinloud
Engine & Internal
Sep 14, 2006 12:08 AM
