PCV valve very loud
Old Aug 28, 2012 | 07:25 PM
Dadatone's Avatar
Dadatone is on a distinguished road
Default PCV valve very loud
This is a bit strange (but then again, this whole experience with my new to me Blazer has been odd). One of the first items I replaced when I purchased the Blazer a month ago was the PCV valve. Now, today, after changing out my plugs to the right AC Delco brand, my PCV valve is making noise like crazy.
Now, the two can't be related, can they?
Here's a video of the valve in action.
Is this something I should be concerned about?
I'm also going to post a thread about the old plugs I just took out. Maybe there is a connection there, I don't know.
pcvclick video by tathal - Photobucket
pcvclick2 video by tathal - Photobucket
Old Aug 28, 2012 | 08:59 PM
spittybays
Guest
Posts: n/a
There should be no relation that I know of, crumby pcv valve? It's hard to tell but on vid #3 just labled tathal think I hear a high voltage snap/tic
Old Aug 28, 2012 | 09:20 PM
Rottidog's Avatar
1st (of 3) vid sounds like a normal PCV out of the valve cover.
2nd is loud & the new PCV hasn't had the chance to get "oily", so it quietens down.
If you want to check for any arcing/spark issue, grab a spray bottle with water & wait till dark or head in the garage & shut off the lights.
Run the engine & spray water from the pump bottle around while you look for arcs. That should tell you if & where you have something jumping to ground & causing a stumbling etc IF it's ignition related to the wires, plugs, dist, coil etc.
One sound I did hear seemed synchronous with timing, so that leads me to think ignition.
You're probably already combining your 2 posts in your head... plugs & this one.
Old Sep 28, 2012 | 02:24 AM
red06sc's Avatar
red06sc is on a distinguished road
The PCV is SO loud on mine. It is still semi new on mine... how can i get that thing to quieten down quicker?
Old Sep 28, 2012 | 07:52 AM
spittybays
Guest
Posts: n/a
Dip it in oil
Old Sep 28, 2012 | 09:14 PM
Leme guess, it's not an AC Delco PCV valve? I've seen, (heard) it countless times with el cheapo aftermarket valves. This is another one of many parts that should only be AC Delco.
Old Sep 29, 2012 | 01:23 AM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
get an acdelco one.... i had same issue then changed the valve with a genuine acdelco one and alls good now
Old Sep 29, 2012 | 02:03 AM
red06sc's Avatar
Mine is a brand new ac delco...
Old Sep 29, 2012 | 06:07 AM
DaveHearne's Avatar
DaveHearne is on a distinguished road
Yep - i'm with the other guys on this one, put a proper AC Delco one in & it'll be quieter, I tried 2 aftermarket ones & they were just as noisy as the old one. Sometimes, but not always, there is a good case for fitting genuine GM spares & this is just one of them.
Old Sep 29, 2012 | 02:32 PM
CAB's Avatar
CAB
CAB is on a distinguished road
I bought one from autozone and it did the same thing. I replaced it with an acdelco and the problem went away.......
