plastic gas tank
Old Aug 1, 2011 | 12:00 PM
ryito1122334455's Avatar
ryito1122334455 is on a distinguished road
Default plastic gas tank
i was wondering if anyone could find a plastic tank for 97 brazer 4 door 4wd...ive serched everywhere and cant find one, will any other model years work??? looking for some imput. i have a nasty leak on my current steel tank...robbing me of my presious gas...really irks my to see a gas stain everytime i move blazer from parking lot....its gotta be around the halfway mark on the tank bc if its under 1/2 theres no drip stain. thanks for responding everyone!
Old Aug 1, 2011 | 12:10 PM
I'd start looking in junkyards. All that I see available is the steel tank even going up as far as a '98. I think the first use of the plastic tank was '97 and that was spuratic. I thought that all '98's had the plastic tank, but that doesn't appear to be so given the lack of availability.
I would look for the actual leak though. You might be able to drop the tank and epoxy the leak to seal it and save a ton of $$$.
Old Aug 1, 2011 | 01:00 PM
ya, i know....didnt wanna go through all the hassle of dropping the tank just to patch it, and have another leak next spring...ohio winters wreak havok on steel tanks....plastic is much to my liking...wonder if any other plastic tanks would fit
Old Aug 1, 2011 | 01:09 PM
The more I looked into it, the more I think that 98 was the first year for the plastic tank and the sending unit also changed then. You may not be able to find a plastic tank for your application.
Have you thought of having a steel tank galvanized prior to installation? Or maybe spraying the outside with a zinc primer then shooting some flat black paint over that?
Old Aug 1, 2011 | 04:36 PM
LRV31's Avatar
LRV31 is on a distinguished road
Originally Posted by swartlkk
You may not be able to find a plastic tank for your application. Have you thought of having a steel tank galvanized prior to installation? Or maybe spraying the outside with a zinc primer then shooting some flat black paint over that?
I agree that this is your best bet. Dorman makes a replacement steel tank [Part # 576-386] that is under $100.
Smc
Nov 14, 2013 04:46 PM
wjdjake
Jul 17, 2011 02:06 AM
Bumbalawski
Aug 4, 2010 05:56 PM
PhiL4x4
Nov 16, 2009 04:05 PM
degaine_designs
Aug 20, 2009 08:15 AM
