Please help
Old Feb 28, 2012 | 07:17 AM
stephanie's Avatar
stephanie is on a distinguished road
Red face ? nut Kit
Originally Posted by Thogert
If it drops it probably means you have a leaking 'nut kit' or a bad fuel pump. If it is the fuel pump, please please please get an acdelco or delphi pump. If you go cheap on the pump, you will be replacing it in a few months.
Hi, recently replaced the fuel pump (within the year) but I dont know what brand it was , I know it was expensive. But everyone keeps talking about the "nut kit", exactly what is this? Sorry for the dumb question !
Old Feb 28, 2012 | 10:03 AM
pettyfog's Avatar
Steph.. sorry for your troubles ..
The 'nut kit' is a short section of fuel lines inside your intake manifold which get brittle and sometimes crack over time.
If your FP press test show pressure dropping rapidly after pump is off, the there's a good chance that either those lines or the fuel pressure regulator is leaking. The third possibility is that the Fuel pump check valve isnt holding Check valves allow flow only one direction.
There is a separate pressure test for that at the fuel filter location but you have to kluge up a connection to do it.
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
