Please help! Blazer Won't Start!!
Old Mar 31, 2008 | 08:01 AM
christyleigh24's Avatar
christyleigh24 is an unknown quantity at this point
Default Please help! Blazer Won't Start!!
Hi I just bought a 2001 Chevy Blazer. Yesterday we went to start the blazer and everything went dead. We thought battery, so we tried jumping it and nothing happened, so we bought a new battery. We got power to the car (lights went on, gauges were reading) but as soon as we tried to start it everything went dead. Has anyone else had a problem like this? Does anyone know what this might be?
Old Mar 31, 2008 | 10:13 AM
Default RE: Please help! Blazer Won't Start!!
This problem is usually linked to a failed ignition switch, but could be corroded or dirty connections at the starter. I would start by checking the main power feed at the starter.
Old Mar 31, 2008 | 02:30 PM
What should I look for to see if it is corrosion or dirty connections? Would I have to take it to a shop to find out if it was the ignition switch? Could it be the starter relay?
Old Apr 1, 2008 | 09:23 PM
You need to look at the battery connections and work from there. I know I said starter, but I was having a brain fart type of day and meant battery. This topic has been discussed quite a bit in the past. Seems some batteries like to corrode on the inside of the battery behind the positive post. If the battery is over 3 years old, I would replace it out of principle. If that doesn't fix it, then I would move on to the ignition switch replacement.
The starter is located on the passenger side as rriddle3 pointed out in your other thread which I have closed.
johndavis0102
Dec 4, 2012 09:25 AM
pipefitter
May 3, 2011 07:14 AM
terry s
18
Sep 20, 2009 10:36 AM
1BSBAKER
Aug 11, 2009 10:54 AM
kwest3208
May 3, 2008 02:00 PM
