PLEASE HELP! Strange issue with new alternator.
Old Feb 14, 2019 | 04:08 PM
Buckys's Avatar
Buckys is on a distinguished road
Default PLEASE HELP! Strange issue with new alternator.
Hey everyone. This is my first post on the fourms. I'm in dire need of some help right now. Here's my issue. I just installed a new alternator on my 2001 LT Blazer 4.3 4x4. When I reconnect the battery, my headlights, dash lights, instrument panel, door chimes etc. all come on. I can hear relays clicking as well. No keys in the ignition. Obviously a massive short somewhere....??? This is my daily driver so any help ASAP would be just awesome! Thank you!
Old Feb 14, 2019 | 04:58 PM
odat's Avatar
Your surging the computer - Hook positive up first then the negative - when unhooking a battery, negative first then positive
Old Feb 14, 2019 | 07:12 PM
Buckys's Avatar
Nope that's not it. Battery was unhooked/reconnected in the proper order. I should add that it won't turn over at all. There's power, but turning the key to start just gets a click and dimming of the lights. Very odd because it still would start, run and drive with the old alternator. That was yesterday. New parts, new problems. Any other suggestions? Almost has to be a short somewhere dosent it? Possibly a pinched or broken wire? Only thing else I can think of is ignition switch? I'm at a loss.
Old Feb 14, 2019 | 08:54 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Reinstall the old alternator, make sure the battery is fully charged and see if it behaves like it did prior to the new alternator installation..
If you had to turn the old alternator in for a core, ask the store if they still have it. Or, explain the issue and see if they will let you try a different new one.
Old Feb 14, 2019 | 09:00 PM
odat's Avatar
hmmm double check the wiring on the new alt make sure all is in the correct positions - I had a vehicle come in that had the black positive lead hooked up as a ground and was doing similar
Old Feb 14, 2019 | 09:59 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Did you confirm that the new alternator was an exact replacement to the old one.It's amazing what some stores pass off as direct replacements now a days. Typically a short would blow a fuse and then nothing would happen.
Old Feb 15, 2019 | 07:45 AM
Buckys's Avatar
Took the alternator back to NAPA. Turns out it was defective. They happily exchanged it and now the Blazer is back up and running. Thanks to everyone here for your input. Seems like a decent bunch of folks around here. I might hang around here more often. Thanks again guys.
Old Feb 15, 2019 | 07:57 AM
CWBDDSPC's Avatar
Glad it's back up and going! Thanks for reporting back too!!
Old Feb 15, 2019 | 09:39 AM
go chevy's Avatar
Glad too hear it is fixed Every now and then even a new part or rebuilt part will be defective sadly...
chevytruckdood
Sep 28, 2011 04:00 PM
jc96blazer
Jul 20, 2010 07:31 PM
Blazer04Noob
Nov 29, 2009 03:07 AM
tycobb280
Oct 9, 2006 06:33 PM
88s10Blazer
May 25, 2006 05:59 PM
