PLEASEE HELP . ABS problems . almost crashed scared to death !
Old Feb 5, 2017 | 12:27 PM
Kcabral26's Avatar
Kcabral26 is on a distinguished road
Yeah mine is weird lol . only happens when I'm slowing down and go left. And I've only seen maybe a handful of people that have explained exactly what I said and that's where I read the thing about it being the opposite side. Now you said you took your fuse out. Did that disable abs all together ? Is it safe ? Like the brakes will always stop me ? Just wondering in case that has to be done. Cause I go down tons of hills daily and drive a lot with my daughter.
Old Feb 5, 2017 | 12:32 PM
Kcabral26's Avatar
Old Feb 5, 2017 | 01:42 PM
The wheel speed sensors can be tested (refer to Tech Article Index for the low speed ABS activation). They can also be replaced independent of the hubs, but if the hubs were just replaced and the WSS signal is found to be at fault, you are entitled to new hubs provided the ones you put in had a warranty. Now if the wire was torn, that is a workmanship issue and really not covered under any warranty, but you could try I suppose.
The fact that it does it when turning a particular direction would lead one to believe that there is excessive play in the new wheel bearing on the right side that pulls the reluctor ring away from the WSS altering the signal and triggering the ABS activation. This would be a warrantable defect.
Taking out the fuse is one way to handle it, but not necessarily the safest way especially if you drive in adverse conditions a lot (heavy rain, loose gravel, snow, etc).
Old Feb 5, 2017 | 01:59 PM
Kcabral26's Avatar
My dad has the truck now , he says its doing while going straight also now. He's going to look at everything today and tomorrow. When I get some answers I'll be sure to update this. Thank you all for now
Old Feb 5, 2017 | 02:00 PM
Kcabral26's Avatar
Sorry and also now when it does activiate and happen the light does go on now. But doesn't stay on
Old Feb 5, 2017 | 02:11 PM
Test the response from each front WSS and report back on your findings. You'll need a multimeter set to the mV-AC setting to test the response. You will also need to have the front end off the ground and safely supported to be able to spin the wheel with the multimeter connected to the WSS connector.
Old Feb 5, 2017 | 07:26 PM
Kcabral26's Avatar
Thank you I will update as soon as He let's me know something. Hoping its an easy fix and be all set tomorrow. Crossing my fingers!!
Old Feb 9, 2017 | 10:08 PM
cdtek101's Avatar
cdtek101 is on a distinguished road
Any news ? Find the issue ?
Old Feb 9, 2017 | 10:12 PM
Kcabral26's Avatar
It ended up being the hub and it was covered under warranty my dad fixed it and everything is great now thank god just had a crazy blizzard over here. Thank you all for the help .
Old Feb 10, 2017 | 06:58 AM
LannyL81's Avatar
Daughters and Dads.........
