po300 check eng light on then went off,why ?
Old Jun 3, 2025 | 06:37 PM
int3414's Avatar
int3414 will become famous soon enough
Default po300 check eng light on then went off,why ?
2001 jimmy,runs really good,sometimes idles a little rough,any ideas on why the light is now out?,,i wouldnt be concerned about this but i need to go thru emissions in oct or nov.,,maybe it needs a ?,crank sensor relearn,is that just a computer thing ,like reprograming the computer?,,thanks for your thoughts
Old Jun 5, 2025 | 08:03 AM
Did the check engine light stay "ON" while running, or did it always go "OFF" after starting the engine?
Old Jun 6, 2025 | 03:05 AM
int3414's Avatar
it was on then off then came on again,now its back on for good?
Old Jun 13, 2025 | 03:02 PM
puttster's Avatar
If it happened over a long period could be the gas cap wasn't on tight and that turned on the light, then you tightened it. Then not tight again....
Could also be someone erased the code and that turned off the light, for a while. But the issue remained and after the next driving cycle it came back on.
Tuna
23
Jun 6, 2015 06:17 PM
wlorton
Sep 5, 2009 10:55 AM
TheGuardian08
16
Oct 3, 2007 06:23 PM
arbowman
Mar 29, 2007 11:46 PM
45auto
Feb 24, 2005 09:30 PM
