Po740 dtc
Old Dec 12, 2014 | 12:36 PM
vetteandblazerman's Avatar
vetteandblazerman has a little shameless behavior in the past
Default Po740 dtc
Just got an check engine light and scanner came up with this code. Checked on line what this code is and came up with "torque con clutch circ malfunc".
I thought engine and trans dtc were separate systems.
Vehicle is running perfectly, does any body know what this dtc means. 1999 4.3 4wd auto.
Thanks Steve.
Old Dec 12, 2014 | 12:49 PM
newguy's Avatar
Old Dec 12, 2014 | 01:16 PM
Good info there,thanks new guy
Old Dec 13, 2014 | 07:43 PM
This might help too. Here's the diagnostic flow chart for P0740, right from the GM shop manual:
https://blazerforum.com/forum/diagno...plained-28391/
Old Dec 14, 2014 | 02:29 AM
Thanks Captain, looks like this will be tricky to pinpoint. I ve been under the vehicle and i can see the electrical connection to the transmission, but work on it, wow!
Steve.
Old Dec 14, 2014 | 11:38 AM
Know what you mean there. The transmission pan must be removed to service the TCC solenoid and or its connector.
nharner
Nov 20, 2011 10:10 PM
TurboGT
Jan 7, 2009 04:07 PM
ESKYMOPACK
Jun 14, 2007 01:27 PM
justlookin
May 2, 2007 07:26 PM
fencr3
Apr 10, 2007 01:13 AM
