position 1 and 2
Old Feb 27, 2008 | 10:02 PM
Nativepenguin's Avatar
Nativepenguin is an unknown quantity at this point
Default position 1 and 2
Of my heater/AC does not work. Any ideas.. im going to take the dash off to see if its fully pluged in.. i dont want to take it in to spend more money... and ideas would help..
thanks
Old Feb 27, 2008 | 10:19 PM
Default RE: position 1 and 2
The resistor pack is on its way out.
It is located under the plastic cover over the HVAC housing in the engine compartment. You will have to cut the cover to get to it. Basically, cut along the dotted line in the pic below:
Old Mar 5, 2008 | 05:59 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
In that diagram if you remove that bolt on the firewall you just have to cut anlong the 3 dotted lines and you can just flip up the rubbery coveragainst the firewallto get the resistor pack out. then just put some black rtv silicone on where the flap meets the box and its sealed and ready to go.
russ1609
Jan 30, 2012 07:08 PM
johnbrown06
Nov 26, 2009 05:16 PM
agent305
Jun 10, 2008 02:56 PM
disturbedgame
Feb 12, 2008 05:32 PM
88blackzcand95blazer
Jan 26, 2007 04:36 PM
