possible brakes issue?
Old Nov 7, 2007 | 07:43 PM
j_mlad's Avatar
j_mlad is an unknown quantity at this point
Default possible brakes issue?
hey i have been having an issue with my truck. when i drive it sometimes sounds like a squeeling sound..no when im on the brake pedal but when im off it. its really pissing me off and i dont know if its a possible warped rotor. or maybe if my caliper is seizing or not.
maybe someone has had the same problem and want to let me know whats the deal lol.
annoying squeeling FTL
Old Nov 7, 2007 | 08:31 PM
Burlisonm's Avatar
Burlisonm is an unknown quantity at this point
Default RE: possible brakes issue?
Have the same problem that started a day after I changed the brakes, I plan on looking at it more this weekend. Let me know if you hear anything or figure something out.
Old Nov 7, 2007 | 08:37 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
If you have not replaced the pads, then it could be a warped rotor or a completely worn out brake pad. Otherwise if you just replaced the pads/rotors did you useanti-squel compound on the caliper pins? Otherwise I am not sure what else could cause this other than surface rust on the rotor.
Old Nov 7, 2007 | 08:45 PM
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
I have the same squeeling sound when I'm driving slowly. Then it dends to go away when I pick up speed
Old Nov 7, 2007 | 08:59 PM
Burlisonm's Avatar
I put on brand new pads and the rotors looked to be in good shape, I also used the anti-squeal.....so I don't know.....guess I will look at it this weekend
Old Nov 7, 2007 | 09:11 PM
I have no clue as to why mine are making that noise. Maybe I need to change them again
Old Nov 7, 2007 | 09:45 PM
If you didnt replace the rotors or have the rotors machined, then that might be the cause of the noise.
Old Nov 8, 2007 | 02:49 AM
thegr81's Avatar
Lennyblazer is right, if you did a pad swap then you need to get your rotors turned. The rotors are probably glazed and needed to be turned. You always want to put a new face to a new face when doing brakes, so that when breaking them in the two faces match.
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
Smoked
Sep 22, 2008 03:17 PM
