Possible vacuum leak, HVAC and lean codes
Old Apr 7, 2023 | 02:48 PM
  #21
99Moneypit's Avatar
99Moneypit is on a distinguished road
It's certainly not going to help! Either way, I'd replace it. Clean the surface really well and be careful with the torque specs when you install the new one. Sometimes you just get a bad part but sometimes we throw an extra ugga dugga or two on there and it bites us later on.
Old Apr 8, 2023 | 02:49 PM
  #22
ferret13sj's Avatar
ferret13sj is on a distinguished road
I found torque spec to be 18 ft lbs or 21 ft lbs. The replacement cheapie egr broke just like the original one did. I just went to the parts store and got a better one. Tightened it and it didn't break.
My new trim numbers are below, first set at idle, second set at 1500rpm. Seems they aren't perfect but much better. Also for fun I am sharing what the broken egr and the mounting surface on engine side looked like, can clearly see a path that doesn't belong there.
Old Apr 8, 2023 | 02:52 PM
  #23
ferret13sj's Avatar
Forgot to say, the exhaust/fuel smell is no longer eye watering or even noticeable. It was very strong before when the fuel trims were up at 50.
Old Apr 10, 2023 | 01:02 PM
  #24
99Moneypit's Avatar
Yeah, I'd say the gasket failed at a minimum. Idle trims seem a little high unless it's still warming up but I'd probably take a 'hide and watch' approach to see what it does with the long term values if it seems to be running okay now.
dlundblad
Jul 4, 2017 11:59 AM
Chlorin8ed
Mar 5, 2016 06:54 PM
sky_blazer
Sep 17, 2013 03:48 PM
ComputerNerdBD
Feb 21, 2012 11:39 PM
armydad71
Oct 31, 2010 12:10 PM
