Possibly inner or outer passenger output bearing (front differential)?
Old Feb 15, 2019 | 05:20 PM
BeaterJimmy's Avatar
BeaterJimmy is on a distinguished road
Default Possibly inner or outer passenger output bearing (front differential)?
Hello everyone,
I need some more help...
can someone tell me, in 2wd, would you hear a bad bearing in the front differential? Ever since I've owned this truck it has sounded like the front passenger wheel bearing was bad. I replaced the hub and it's still there - it's actually just gotten worse in the past couple days. It sounds exactly like a bad wheel bearing.
I also plan to replace the drivers side this weekend just for the hell of it, I guess..
My only other thought was that maybe the inner or outer output shaft bearing has gone bad, but it makes noise in both 2 or 4wd. If those bearings are inactive in 2wd, then what else could it be? This is a 3 switch, part-time 4wd SLE.
Thank you for any help offered
Old Feb 15, 2019 | 05:24 PM
I mean, they would have to still be spinning right? They just aren't under power... so it could very well be a bad differential bearing...?
The differential doesnt leak fluid, and in fact the fluid was just changed about a month ago.
Old Feb 16, 2019 | 04:49 PM
eshaw's Avatar
It could be a bearing. The shaft is still spinning in 2wd even though 4wd isn't engaged, the bearings are still spinning.
Old Feb 17, 2019 | 06:09 PM
Ditto for the CV axles always rotating even when in 2wd.
When you do the driver's side, use enough of the sealant for the cover. It is not very hard to replace the bearing either when you are in there.
I've attached pages from my 1999 service manual that I found useful. A crow's foot and a ratcheting box-end wrench are super useful for a couple of the bolts.
Allan
May 18, 2014 11:03 PM
Biohazed
Oct 13, 2009 09:21 PM
mikes93s10blazer
Aug 16, 2009 07:48 PM
Red Dog
Dec 5, 2007 07:29 PM
dBsound
Mar 2, 2007 01:16 AM
