Power Brake Boster bolts - help!
Old Feb 16, 2008 | 09:45 PM
tommychet's Avatar
tommychet is an unknown quantity at this point
Default Power Brake Boster bolts - help!
I have a 1998 blazer 4 door and i am in process of replacing the power brake booster. after a herculean effort i got 3 of the 4 nuts off the mounting studs under the dash. the last one is behind the steering column mounting bracket. is there an easy way to get this bolt off? is there a special kind of wrench that would work in this tight spot? any hints, i could sure use one.
Old Feb 16, 2008 | 10:20 PM
zombiewoof's Avatar
zombiewoof is an unknown quantity at this point
Default RE: Power Brake Boster bolts - help!
the first one i did I uesd a wrench...PITA....the second one I did I used a wobble extension with a universal joint type adapter and a swivel head ratchet....basically formed 2 90 degree angles with the ratchet and extensions..was still a pain but definatly easier the second time.....getting it started when putting it back on was even worse...I almost left it off...
Old Feb 17, 2008 | 12:05 AM
Chevy Lover's Avatar
I've used an extension to a universal joint, then another extension and a flex socket. I've put a little putty into the socket so that the nut sticks in to put them back on.
Old Feb 26, 2008 | 08:19 PM
tommychet's Avatar
thanks guys. i finally got it done. the first u-joint broke to bits as soon as i turned it, but finally was able to get the nut off
Old Feb 27, 2008 | 02:30 AM
thegr81's Avatar
Glad you got it!! Break boosters are a pain, I did my buddy's on his fullsize chevy and it was no picnic either!!!
Kjared2
Oct 31, 2010 08:54 PM
ayagle
Aug 31, 2010 02:15 AM
SCBlazer96
Apr 16, 2010 08:39 PM
F T P
Jul 31, 2009 07:41 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
