Power door lock problem
i have a 95 blazer and when i hit the keyless entry unlock button, it only opens the driver side door. i hit the button again and it sounds as if the other doors are trying to unlock, but they dont. the lock button and the rear hatch button work fine. then ill get into thecab andi will press the unlock button on the door panel and i get the same sound, but they dont unlock. butpressing theitto lock button will work. i have to manually reach over the seat to unlock the passanger door. any ideas?
Is this a 2dr or 4dr? Sound like a bad actuator, but if its a 4 dr one bad actuator could short preventiong the others from working. If its 2dr, then pretty much it can only be the passenger side. One thing to check, open the pasenger door wide, and cycle the locks. If it works fine then you may have a shorting wire, or degraded wire in the molex that goes from the door to the doorjamb. If the problem persists I'd say you'll be changing the actuator on that side. You can fit in a generic aftermarket one instead of the factory GM piece though.
Julian
Julian
I think he is reffering to changing the passenger side, I have the same exact problem on my 4 door. I just have to get around to changing the actuator. If your looking for a cheaper than factory bought actuator try ebay.
dardamar
Oct 8, 2008 02:03 AM
muszyngr
Apr 23, 2008 02:55 AM
muszyngr
Apr 8, 2008 01:24 PM
