Power door lock problem
Old Oct 11, 2008 | 01:06 PM
vtboss54's Avatar
vtboss54 is an unknown quantity at this point
Default Power door lock problem
i have a 95 blazer and when i hit the keyless entry unlock button, it only opens the driver side door. i hit the button again and it sounds as if the other doors are trying to unlock, but they dont. the lock button and the rear hatch button work fine. then ill get into thecab andi will press the unlock button on the door panel and i get the same sound, but they dont unlock. butpressing theitto lock button will work. i have to manually reach over the seat to unlock the passanger door. any ideas?
Old Oct 13, 2008 | 07:40 PM
fattyfatty's Avatar
fattyfatty is an unknown quantity at this point
Default RE: Power door lock problem
Is this a 2dr or 4dr? Sound like a bad actuator, but if its a 4 dr one bad actuator could short preventiong the others from working. If its 2dr, then pretty much it can only be the passenger side. One thing to check, open the pasenger door wide, and cycle the locks. If it works fine then you may have a shorting wire, or degraded wire in the molex that goes from the door to the doorjamb. If the problem persists I'd say you'll be changing the actuator on that side. You can fit in a generic aftermarket one instead of the factory GM piece though.
Julian
Old Oct 14, 2008 | 08:44 AM
vtboss54's Avatar
I have a 4 dr. Which side are you refering to when changing the acuator, psng or driver?
Old Oct 14, 2008 | 09:00 AM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
I think he is reffering to changing the passenger side, I have the same exact problem on my 4 door. I just have to get around to changing the actuator. If your looking for a cheaper than factory bought actuator try ebay.
cochran07
Sep 18, 2012 12:11 AM
greenbean
14
Feb 7, 2010 08:02 PM
dardamar
Oct 8, 2008 02:03 AM
muszyngr
Apr 23, 2008 02:55 AM
muszyngr
Apr 8, 2008 01:24 PM
