Power mirror repair
Old Jun 28, 2016 | 10:36 PM
rok55's Avatar
rok55 is on a distinguished road
Default Power mirror repair
The up/down function on my 2000 Blazer drivers side mirror doesn't work, you can hear and feel the motor running but get no movement. A little investigation found the actuator stem is separated from the drive motor. I think I can repair it if I can remove the mirror (glass) assembly from the housing. Can the mirror be removed for service .... how?
THanks in advance for the help.
Old Jun 29, 2016 | 07:12 AM
Tajohns34's Avatar
I have never tried to repair a power mirror before since they are so cheap. A new power, heated mirror is around $35 from Amazon. You could probably get one for about $10 - $15 from a junk yard. As far as removing it, If you remove the door panel you should be able to unbolt it and disconnect the wiring.
Old Jun 29, 2016 | 05:35 PM
rok55's Avatar
Mirror is already off car and on bench for repair. Tried to remove mirror without success in fact broke the glass so guess I'll be visiting the local pick n pay for a replacement.
Old Jun 29, 2016 | 05:45 PM
rok55's Avatar
Admin, Please delete the thread
cwalker84
Jun 1, 2020 09:54 PM
JohninMass
Nov 28, 2009 09:14 PM
Sherwood
Oct 12, 2007 09:21 PM
onebadapple
May 12, 2006 06:19 PM
Blade69
Apr 30, 2005 10:12 PM
