Power steering Leak
Old Jul 13, 2014 | 03:20 PM
Richie Webster's Avatar
Richie Webster is on a distinguished road
Default Power steering Leak
Hey Guys, I normally only drive my bravada during the winter, but I went to move it today and noticed the power steering pump groaning. Sure enough, I was almost out of fluid. I put more back in and it just puked it back out. I tore apart the front end today, and took a look at the power steering cooler. It is rusty, but it is not leaking from it. I dropped my plastic skid plate, and almost all of the fluid drips down above the oil filter. I am wondering without tearing too much more apart, if you guys could tell me which line is leaking? Thanks so much!
Old Jul 15, 2014 | 03:40 PM
fletch125's Avatar
fletch125 is an unknown quantity at this point
Probably just a line. They rust around the fittings(extremely common in states where they use salt) and leak. There are 2 hoses(hi and lo pressure). If theyre leaking from the fittings it will be obvious because the lines will be wet and dirt and grease will collect on them. Raise and support the front end and have someone spin the steering wheel with the engine running and see if you can spot any leaks
Old Jul 18, 2014 | 07:06 AM
Tajohns34's Avatar
I just bought all new lines for mine, cost around $30 at advance. I haven't put them on yet as mine isn't actually leaking, but my lines are definitely old.
UberFail
Nov 12, 2010 10:20 PM
Zerbla96
Apr 25, 2010 11:35 PM
IROCZer
Jan 28, 2010 12:50 PM
SuperMuise
Apr 17, 2009 05:15 PM
dax44
Aug 31, 2008 08:00 PM
