Power window roller problem
The driver's window on my 1999 Blazer is off track, I took off the door panel and saw that one of the arms pulled out of the roller on the track. I pushed it back in, sprayed some silicone grease in the tracks and worked the window up and down a few time. It worked fine so I put the door panel back on and now it is doing the same thing again. Did I just not push the arm into the roller hard enough, should it pop in or do I need to replace something? Also, what would cause this, I have read that there are guides for the window, could one of those be bad and cause this? If so, where are they so I can check them?
Thanks for any help.
NOs
09-01-2016 12:09 PM
Manteray
04-12-2010 04:36 PM
