Problem after Heater Core Replacement 2000 chevy blazer
Old Jul 26, 2012 | 06:00 PM
zantam06's Avatar
zantam06 is on a distinguished road
Default Problem after Heater Core Replacement 2000 chevy blazer
A friend recently replaced heater core but, must have left something undone. Afterwards there is no power to blower or controls. Can someone tell me what might be unplugged.
Old Jul 27, 2012 | 06:04 PM
step66's Avatar
Yup-they neglected to re-hook the wiring harness to this module in their haste to finish the job,you should not have to remove the dash again but you might have to drop the steering column again.Or if you get lucky you may be able to reach them with the radio and lower duct work removed.Best of Luck!
Old Jul 27, 2012 | 07:16 PM
warthogdriver's Avatar
i would remove the front bezel trim and pull the unit out then check the connections.
looks like the devil is hiding in your details.
Old Jul 30, 2012 | 02:00 AM
zantam06's Avatar
Is this harness located near the steering column and do you know if it has a colored connector or a white one. Or in the middle near the radio.
Old Jul 30, 2012 | 12:36 PM
zantam06's Avatar
I see one plug (white) on the passengers side hanging down but don't know where it plugs into. I think the plug is closer to the middle just hanging down on the passengers side.
Old Aug 4, 2012 | 02:00 AM
zantam06's Avatar
s this harness located near the steering column and do you know if it has a colored connector or a white one. Or in the middle near the radio. I see one plug (white) on the passengers side hanging down but don't know where it plugs into. I think the plug is closer to the middle just hanging down on the passengers side.
jewag87
Mar 30, 2015 04:31 AM
justblazin1
Nov 17, 2013 12:53 AM
dagunrpuppet
Nov 10, 2012 09:18 PM
piperarrow
Oct 6, 2012 03:53 PM
scrounger
Nov 11, 2009 10:35 AM
