Problems in Rain
Old Mar 31, 2010 | 08:22 PM
maddzz's Avatar
maddzz is on a distinguished road
Default Problems in Rain
I am new to blazers and previously only have experience with jeeps. 97 blazer 4x4 4.3
Whenever it rains and I drive the truck in the morning it seems to hesitate/lurch when under acceleration. After driving it and then restarting the problem is gone.
After the rediculous amount of rain in RI this week the truck would not start at all, would just crank. Let it sit overnight and still same thing. Opened hood to let some air blow thru to try and dry and after an hour it started but was doing the hesitating/lurching when under load again.
Is it common for these trucks to leak around the front doors? If so, do the newer years have thicker whether stripping than can be swapped in?
Old Mar 31, 2010 | 08:32 PM
1998ZR2's Avatar
1998ZR2 is on a distinguished road
sounds like your plug wires need replaced. try and search door pins or bushings and you should find more info on the door problem
Old Mar 31, 2010 | 08:43 PM
x2 on the ignition system being the source of the problem. I would try misting down your engine with water. Run the engine while you mist down the wires, coil, ICM, and distributor.
Door bushings are very common and covered pretty good in other threads as suggested.
bjsx8f
Mar 14, 2016 04:33 PM
Eddie Clark
Dec 10, 2012 04:07 PM
shotnva777
25
Sep 27, 2011 07:04 PM
PawNtheSandman
Engine & Internal
23
Aug 27, 2006 11:22 PM
blueice01
Jul 3, 2005 08:50 AM
