problems starting
Old Jan 26, 2007 | 11:38 AM
mustangdan1963's Avatar
mustangdan1963 is an unknown quantity at this point
Default problems starting
I have a question on a 2000 blazer. It has problems starting, not every time, but two or three times a week. When you jump it it starts right up, but when you put a charger on the battery is shows full charge. This morning, it wouldn't start at all, and just "clicked" when she turned the key? Any suggestions?
Old Jan 26, 2007 | 12:20 PM
Default RE: problems starting
I forgot to mention that the alternator is new. Could it be the solinoid?
Old Jan 26, 2007 | 01:36 PM
spiritwild's Avatar
spiritwild is an unknown quantity at this point
I have had similar problems with my starter going bad, I always thought it was the battery but I was wrong.
It was binding up and pulling way too many amps, it would drain the battery enough the first try to where it would not charge up fast enough on a short trip. Thus the second start was either slugish or solenoid click.
It gets worse when the engine is hot, the heat from the motor will cause moving parts to expand a bit and if their bound up cold the really bound up when hot.
It misled me because a battery will charge itself when left sitting enough to start after work. I had the starter tested at the parts shop and it actually grenaded right in front of them. I replaced the starter and have not had a problem since.
Also, it was worse in colder weather.
I would have the starter tested and the batttery just to rule it out also.
Old Jan 26, 2007 | 02:33 PM
blazerlt01's Avatar
blazerlt01 is an unknown quantity at this point
also check all of your connections, vibration from the motor running or going over potholes or really rough terrain can loosen your connections enough if they weren't completely tightened the first time. good luck
Old Jan 26, 2007 | 02:59 PM
thanks for the tips!
cgrett
Nov 15, 2010 09:08 PM
upblazer95
Apr 4, 2009 08:27 PM
Sprocket
Mar 20, 2008 09:39 PM
Dean S
Jan 30, 2006 02:51 AM
smplgrn
13
Jan 23, 2006 09:02 PM
