pulling engine without a torque converter cover shield
Old Feb 21, 2011 | 01:11 PM
brandon1029's Avatar
brandon1029 is on a distinguished road
Default pulling engine without a torque converter cover shield
I'm having trouble pulling my engine because i don't have a torque converter shield as in i cannot separate the torque converter from the driveplate because there is no access to it. does anyone have any suggestions?
Old Feb 21, 2011 | 02:28 PM
BLAZERMAN911's Avatar
Banned
BLAZERMAN911 is on a distinguished road
there should be a cover under the truck to expose the flywheel. its called a inspection plate. remove it and u will need to use a wrench to remove the tourqe convertor bolts from flywheel.
Old Feb 21, 2011 | 02:30 PM
i mean there is no inspection plate... like the bell housing is 360 degrees... cast all the way around the torque converter
Old Feb 21, 2011 | 02:52 PM
Banned
yes it comes off about halfway up.
Old Feb 21, 2011 | 05:23 PM
all i have is a hole about the size of a silver dollar. which is pretty much useless because you can't get to the torque converter bolts through it. there is no half cover like most transmissions
Old Feb 21, 2011 | 05:56 PM
This is what my tranny is like
Old Feb 21, 2011 | 06:01 PM
Banned
ouch. ya i would say that you will need to remove tranny first then.
Old Feb 21, 2011 | 06:37 PM
caditech's Avatar
caditech is on a distinguished road
no you should just be able to remove the starter and take your flexplate bolts out through that opening.
Old Feb 21, 2011 | 09:55 PM
LowLife's Avatar
LowLife is on a distinguished road
no u take the 2 13 or 14mm bolts out the starter move that out of the way then remove the plate under the starter with 2 8 or 10mm tiny lil bolts and through the hole in your bellhousing on the bottom stick a flathead in the flexplate to hold it while u crack the bolts loose and use the flathead also to spin the flexplate to get the bolts where u need them to remove then just remove the 3 13 or 14mm bolts that hold the torque converter to the flexplate simple as that all by yourself
Old Feb 22, 2011 | 02:41 PM
Doug W's Avatar
Doug W is on a distinguished road
This is correct, I just did it 2 days ago.
