question on 4 wheel drive
Old Apr 15, 2015 | 02:15 PM
monkey23's Avatar
monkey23 is on a distinguished road
Hi I checked the bstl fuse again in the run position I checked it in both park and neutral and got no battery voltage at all I also checked the crank fuse with the car off and in the run position and there is no battery voltage on it eather
Old Apr 15, 2015 | 03:09 PM
BTSI fuse gets power through the transmission range switch from the back up lamp fuse in the underhood fuse panel. Need to trace that back to find the open circuit, might be the fuse, or a broken wire.
....I also checked the crank fuse with the car off and in the run position and there is no battery voltage on it eather
That's correct, it shouldn't show voltage then. CRANK fuse 10 amp must show battery voltage in the START position.
Old Apr 16, 2015 | 09:14 AM
monkey23's Avatar
The crank fuse does not show any voltage at all in any position
Old Apr 16, 2015 | 10:09 AM
See post #9.
mirrorimij
Jun 8, 2019 03:34 PM
lizzj70
Jun 23, 2010 06:57 PM
vortecblazer4wd
Feb 8, 2009 09:50 PM
Huxley
Dec 30, 2008 03:06 PM
Helter80
Dec 25, 2008 08:58 PM
