Question about cluster
Old Sep 8, 2008 | 11:03 PM
ilpipe's Avatar
ilpipe is an unknown quantity at this point
Default Question about cluster
Hi guys, I have one question. I want to put the 2005 gas cluster in my truck (I have a diesel truck). The question is, could I put it? Will the RPM gauge work?
My cluster is like this.
http://img329.imageshack.us/img329/7750/camioneta30082008013rc2.th.jpg
And I want to put this cluster
http://ebay.schramauto.com/MISC/15132449-01.jpg
Can I install it? Will it work?
Thanks a lot,
Luciano
Old Sep 14, 2008 | 05:30 PM
ilpipe's Avatar
Default RE: Question about cluster
Nobody know?
Old Sep 14, 2008 | 07:54 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Im guessing you would have some issues, the rpm would probably register correctly, but this would only use part of the tach. Also isnt there a glow plug indicator on your current cluster. They probably have a different harrness but you could rig out something im sure.
Old Sep 14, 2008 | 08:41 PM
Not sure anyone outside of your region would know... I have no information regarding the diesel engine nor the wiring for the particular cluster you are using.
Very likely, the RPM will be incorrect. As will the speed...
Old Sep 19, 2008 | 06:57 AM
ilpipe's Avatar
Thanks a lot, but i think that is the same cluster. I´d could find the pinout of the Canadian cluster (Km/h and °C) and the Brazilian cluster; and see if it the same or not.
Old Sep 19, 2008 | 07:55 AM
I will say that the pinouts will likely be the same. However, given that the scales for the tachometer and speedometer are different (something that is programmed into the PCM for a given RPO code), I do not think that the different cluster will display the RPM and speed properly.
blazerguy09
Jan 7, 2015 03:26 PM
Drew14221
Jun 19, 2010 04:48 PM
3kidblazer
Feb 1, 2009 11:22 PM
WLB
Mar 3, 2008 10:08 AM
wolv2401
Jan 20, 2007 02:08 AM
