Question about noise
Old Jan 2, 2013 | 02:31 PM
IanD's Avatar
IanD is on a distinguished road
Question Question about noise
Hi everyone,
I have a question about a noise that happens every time I hit / go over a bump. On the driver's side, I hear what sounds like metal hitting metal, a clunking / knocking sound. Any ideas as to what it could be? The passenger side, from what I can hear, sounds fine, if that's any help.
Thanks in advance.
Old Jan 2, 2013 | 03:24 PM
Dubie81's Avatar
Dubie81 is on a distinguished road
Front or rear?
Suspension would be the first place I look, though there are a few things that can get loose or worn and could make such a noise...
Old Jan 2, 2013 | 04:12 PM
newguy's Avatar
Check your sway bar end links or bushings
Old Jan 2, 2013 | 04:35 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Aong other suspension parts check your front shocks.The rubber bushings on them could be deteroratedAnother thing worst case is maybe one of rubber body mounts has rotted out.
Old Jan 2, 2013 | 04:48 PM
xgiovannix12's Avatar
Bump stops shot? check your bump stop . Also check your torsion bar mount.
Old Jan 5, 2013 | 10:13 PM
IanD's Avatar
It's in the front (Dubie). It could be the bump stops, I'll check them out when I change my wheel hubs.
I don't know if it would be the sway bar, This noise only happens when there is vertical flex on the front end suspension.
Old Jan 5, 2013 | 10:15 PM
IanD's Avatar
Also, just to put it out there, I have just recently lubed up the majority of the zerk fittings. Is it possible that these grease fittings have anything to do with the squeaking that accompanies the metal on metal sound?
Old Nov 5, 2019 | 01:07 PM
ZR2owner's Avatar
ZR2owner is on a distinguished road
Originally Posted by IanD
Hi everyone,
Thanks in advance.
Front end noise. Check the hood hinge bolts. When loosen up it sounds like all those things. The sound seems to come from the bottom of the firewall. It resonates all thru the frame that's why it's so hard to pinpoint. Chevy makes a bushing for the hinge pin bolts.
Old Nov 5, 2019 | 02:42 PM
I had such a noise in my 92 when the rear attachment for the torsion bar broke.
Irish07
Oct 31, 2012 06:04 PM
nakedredneck
Jan 8, 2011 12:05 AM
iamchevyman5
Nov 17, 2010 06:30 PM
Chrismacster
Apr 2, 2009 06:57 PM
chizz42
Dec 8, 2007 07:54 PM
