Question about noise
Hi everyone,
I have a question about a noise that happens every time I hit / go over a bump. On the driver's side, I hear what sounds like metal hitting metal, a clunking / knocking sound. Any ideas as to what it could be? The passenger side, from what I can hear, sounds fine, if that's any help.
Thanks in advance.
Thanks in advance.
Aong other suspension parts check your front shocks.The rubber bushings on them could be deteroratedAnother thing worst case is maybe one of rubber body mounts has rotted out.
It's in the front (Dubie). It could be the bump stops, I'll check them out when I change my wheel hubs.
I don't know if it would be the sway bar, This noise only happens when there is vertical flex on the front end suspension.
Also, just to put it out there, I have just recently lubed up the majority of the zerk fittings. Is it possible that these grease fittings have anything to do with the squeaking that accompanies the metal on metal sound?
Hi everyone,
Thanks in advance.
Thanks in advance.
Irish07
Oct 31, 2012 06:04 PM
iamchevyman5
Nov 17, 2010 06:30 PM
Chrismacster
Apr 2, 2009 06:57 PM
