Question about upper intake??
Old Apr 9, 2012 | 06:19 PM
red06sc's Avatar
red06sc is on a distinguished road
Originally Posted by Captain Hook
Piece of cake... Remove the distributor cap. Bump the starter until the rotor points directly at the "6" on the distributor housing. Disconnect the negative battery cable. Remove the distributor. When you reinstall the distributor, make sure the rotor points to the "6" when the housing is fully seated against the intake manifold. Reconnect the battery cable. Disconnecting the battery cable ensures the crankshaft doesn't move while you've got the distributor out. (As long as you don't move the crankshaft while the distributor is out, you'll be fine.)
i think im having this issue...so what happens if it dont point to 6?
Old Apr 9, 2012 | 07:35 PM
The only reason for setting the rotor to the "6" before you pull the distributor, is so you know exactly where it goes when you reinstall it. The key here is, DON'T move the crankshaft while the distributor is removed. There's also an "8" on the distributor housing, and you can align the rotor there if you want, it doesn't matter which mark you use, the important things are put it back in the same place, and don't move the crankshaft.
On a V6 engine that is timed correctly: when the rotor is pointing to the "6" on the housing, it means #1 cylinder is at TDC of its compression stroke and ready to fire the spark plug. The "8" means the same thing for a V8 engine.
Old Apr 10, 2012 | 12:15 AM
4x4blazerguy's Avatar
I took it to a shop today & the owner worked for a Chevy dealer for 10 years. So it was real easy for me I sat & drank coffee. He replaced it with a FelPro gasket, What he told me is the FelPro is a bit thicker & doesn't crush as bad as the OEM gasket. He said once you change them with the FelPro gasket the likely hood of ever doing it again is very remote.
I had the cooling system flushed & new DexCool put in. Someone put on a new water pump & radiator & put the old DexCool back & topped it with green. So he cleaned out the tank also. So I'm set to go & didn't even get my hands dirty.
Thanks for all the info.
Old Apr 10, 2012 | 02:57 PM
Felpro gasket is totally different design than OE. Yes, it's thicker, but it's made out of real rubber and steel, not plastic and silicone rubber. If it's installed correctly, it won't leak. Dexcool and ethylene glycol when mixed together, turn into a brown mud and can be rather difficult to clean out. The main problem with using the green stuff in a Dexcool system is that the green is far more abrasive and prematurely destroys the water pump seal.
Old Apr 10, 2012 | 11:47 PM
That explains the crushing of the OEM gaskets. Yea I have seen what happens when you mix green & Dexcool. It got cleaned out & I now have nice clean orange anti freeze. I'm taking a trip in a few days I'm headed to Mopars @The Strip in Las Vegas. for a hopefully a nice weekend of drag racing. My buddy owns a race team of Mopars & he & his boy will be racing. So I will get a nice pit seat & enjoy the event. I own two Mopars myself. I own a Dodge 2500 4x4 QC V-10 5speed, & a Jeep Grand Cherokee 5.9 Limited. But to be honest I find the Blazer 4x4 to be my choice of road trucks. The Jeep is fast but it isn't as comfortable & it likes gas. My Dodge V-10 has one job & that is to tow our 10,000 travel trailer. It does that real nice & easy. If it got the mileage or close to the mileage of our Blazer I would make it my road truck. But 12 MPG isn't enough.
Old Apr 16, 2012 | 09:57 AM
kary1982v6's Avatar
kary1982v6 is on a distinguished road
if you have to get in deeper, this vid may help..
https://www.youtube.com/watch?v=WVTFRgw57M0
ABN31B
Engine & Internal
15
Jan 8, 2011 03:43 PM
AuSSenseiter
Dec 23, 2010 07:38 AM
rasputinlv
Nov 9, 2010 02:40 AM
benshuey
Feb 21, 2010 09:18 PM
Jerseyboy
Apr 27, 2006 03:28 PM
