Quick 4wd question
On a 2002 4dr 4wd with the four buttons (2HI, 4Hi, 4Lo, Auto) system; front diff is not locking.
The acutator is good under the battery.
My question is regarding the vacuum switch mounted on firewall center. I put a vacuum gauge on the actuator side and selected 4Hi, no vacuum. I have vacuum going into the switch. So easy....bad switch....removed vacuum switch and checked to see if voltage is at electrical connector when selected....yep....12 volts....
Applied 9 volts from a battery across vacuum switch to see if it would switch....nothing. So I measured the resistance across the terminals and it was about 88 ohms...which seems high. I then applied 12 volts using Blazer battery and it switched...but I think I got a bit of smoke....just did a quick tap when applying voltage.
Reconnected everything and still no 4wd.
Anyone know what the coil resistance should be for the vacuum switch? Or should I just replace it?
Thanks
Thanks
The TCCM switches the ground side of the circuit, not the positive. I would recommend taking Captain's advice on testing for a good switched ground before throwing parts at the problem.
Wiring & vacuum diagrams are in the tech article sections.
Looks like I killed the vacuum switch when I applied 12 volts from the battery. Measured the resistance across the terminals.....zero...so I have shorted it out.
I had ordered the replace switch anyways....good thing.
Installed switch today, drove to a patch of loose gravel, pressed 4 HI button....light on 4HI came on steady in about 3 seconds. Yes!!!!
Tried 4LO...quickly switches, light steady.....in 4LO...!!!!!!
Went back to 2HI....felt front diff unlock....yep back in 2HI.
I am good to GO!
Got the switch off of ebay, supposed to be a GM part....appears to be.
I am good to GO!
