quick question re:removing plug wire at cap
hi
Curious, a lot of youtube videos on troubleshooting a misfire start with the engine running and then pulling one wire off at a time.
Can we do that with our 2005 blazers?
Does it ruin anything?
Do blazer owner/mechanics use this as a valid test?
Or is it easier to just put a timing light on the wire see if the pulse is there?
Can't see why it would hurt anything on a 2005 - I do it all the time when needed - by pulling one wire at a time you are not looking for spark you are seeing if the miss increases by shuting down that cylinder - if the miss doesn't change when the wire is pulled that will be your problem cylinder - most times you can check for a rod knocking in this manner also, pull the wire and the knock quiets down that will be the bad cylinder
![Icon Clapclap](https://blazerforum.com/forum/images/smilies/icon_clapclap.gif)
Just letting everyone know I did the test, started it up, pulled a plug wire off at CAP and you could tell FAST that the engine totally sputtered 10 times worse.
So this helps rule out a dead cylinder or a misfire on one of the cylinders as being a plug or plug wire doesn't IT!
yup, I pulled every plug (except one) and you could tell immediately it ran like ***. I couldn't get one in passenger side nearest firewall to come off because of stupid tranny dipstick in the way
who knows maybe that is one, lol
red1127
21
09-08-2018 05:03 PM
futuredoc
06-28-2010 02:50 PM
jstein
06-27-2010 10:38 AM
boulonman
03-05-2007 05:10 AM
