Quick rear window washer repair fix
Old Feb 27, 2011 | 05:51 PM
das96blazer's Avatar
das96blazer is on a distinguished road
Default Quick rear window washer repair fix
During the daily tasks we all seem to put our blazers thru I am sure sooner or later someone has or will break the fragile little connector that the rear washer hose connects to. With this part being old and brittle I broke mine while cleaning the back hatch glass. When it does break, the little nipple end will almost surely still be stuck in the hose. Leave it there as here is a quick and easy fix that works. With the nipple part still inside the hose, cut about an inch piece of the straw that comes with a can of carb cleaner or some other spray cleaner and insert half it in the hose and the with the other half sticking out attach the hose as far as you can back into the broken end of the fitting. Fits like a charm and no leaks. Push it all the way in and you will never even see the piece of the straw.
Old Feb 28, 2011 | 05:11 PM
step66's Avatar
I gave up on that system years ago-use rain-x and a squeegee! step66
Old Mar 27, 2011 | 02:44 PM
mikebugman's Avatar
mikebugman is on a distinguished road
that was priceless been reading a ton of post to fix wifeys toy for awhile now
Old Apr 3, 2011 | 03:39 AM
EdC's Avatar
EdC
EdC is on a distinguished road
Default Rear window washer repair.
In regards to the washer, I have a fairly simple question. Where the )(*&^% is the tank. The manual says it could be either the regular tank (don't hear the pump run when I hit the button) or in the wheel well behind the spare. I've got a 2000 s10 2dr 4x4 with the spare inside. and there is no tank in that space behind the spare. I bought is at 24k miles 6 yrs ago and now have 164 on it, so I have had time to look.
e602
91
Mar 8, 2015 04:53 PM
strange
Dec 24, 2014 05:31 PM
kmartin
Apr 27, 2009 10:01 PM
MarkARos
May 5, 2008 11:36 PM
riceh8r0512
Dec 31, 2007 07:37 PM
