Quick starter replacement question...
Old Jan 31, 2019 | 04:22 AM
  #51
porkfriedrice's Avatar
porkfriedrice is on a distinguished road
Originally Posted by mojarraman
Quick Q:
it was oily down there, and shop last year looked quick and (incidentally) quipped: "LIKELY oil-line(s) to radiator leak". And is likely one, or both, or (any liklihood) which of two?
So, CAN those ever be fixed by just tightening (aprox. 150k miles)? Any odds, Lol? Could post "elsewhere," but thought I'd give quick inquiry here to start. Thanks kindly.
The oil cooler lines leak where the rubber hose is crimped to the metal pipe. Can't be tightened. Common Blazer problem, and it seems no matter what brand replacement you buy they will eventually start leaking. If you search the forums there are threads by people who have come up with their own permanent fixes to the problem.
Might want to check ASAP if the leak is coming from the oil lines, the hose will eventually pop off the fitting which will leave you on the side of the road. Happened to me on my first Blazer, didn't know about all the Blazer quirks back then.
Old Jan 28, 2022 | 07:10 PM
  #52
mjohnson52575's Avatar
mjohnson52575 is on a distinguished road
Default 2000 blazer 4x4 starter removal
Remove the nuts from the rubber tranny mount. Jack the tail of the tranny up as far as it will go (carefully). I recommend jacking it up facing the jack towards the front or rear not side to side.This will keep you from binding the exaughst or other parts that could be broken because being put at a bind.This makes the opening just wide enough to get the oem starter out. Remanufactured starters have a smaller body than the oem. You will not have to do much to get them in or out, there is more than enough room for removal and install.
Old Feb 6, 2022 | 06:45 PM
  #53
Tajlyon's Avatar
Tajlyon is on a distinguished road
Originally Posted by redcrbbr
Well first off, thanks for all the help from this forum. It saved me alot of uneeded work. the starter was out in about 5 minutes after flipping it around and back in about the same.
The idea that I had to jack the engine came from the autozone online repairs manual. thank you again.
I had same problem when replacing starter in my 2001 blazer. But I also had a broken motor mount that I was unaware of at the time, so I did have to jack engine up just a bit to get starter out after rotating it. It helps to have small hands as well. And I was able to fix motor mount afterwards.
Old Feb 14, 2022 | 07:47 PM
  #54
Graveyard's Avatar
Graveyard is on a distinguished road
Hello, I just replaced mine on my 96' S10 Blazer. Took off the front passenger tire to get to the wires...still a very tight fit. I couldn't get my hand in enough to even screw the nuts off with my fingers but I could see the nuts and get an open end wrench on them.
Next problem... Once I got the starter unbolted, it would not come out until I actually rotated the started 180 degrees from the original mounting direction. This is very tedious also. Once it's rotated, then I had to roll the starter until I found a "sweet spot" that would let the starter slip out. You have to do the same thing to get the new one in. It's tough but I didn't remove the O2 sensor, didn't jack up the tranny...nothing. It's something I hope I never have to do again but now I know the trick. Took me about an hour and a half.
Good luck
Old Nov 23, 2024 | 02:12 AM
  #55
Dicky redmond's Avatar
Dicky redmond is on a distinguished road
Originally Posted by ricks
Just finished replacing the starter, struggled all morning until I reached through the fenderwell with a 1/4" ratchet and 8mm and 13mm sockets and removed the wires. Then used a 1/2" ratchet and 13mm socket from under the jacked up vehicle to remove the 2 bolts. Pulled it out of the bellhousing and rotated it 180 degrees and it slid right out. Previously tried pulling it out gear end first without success. After figuring out the process, only took another half hour to do the reverse and get it back together.
Hope this specific information helps somebody.
When you unbolt the starter back it out turn the starter 180 degrees in it's place lift the back of the starter nose down and wiggle and turn it until you find the sweet spot that's the only way it will come out and the only way it will go in period without removing anything then you can remove the wires no problem no expert just been there done that
Old Nov 27, 2024 | 09:31 AM
  #56
puttster's Avatar
Thank you for the specificity.
Albundy
Dec 20, 2010 12:49 AM
marklar
Aug 26, 2009 08:19 PM
Shaid
Jul 15, 2009 02:57 AM
jukdd
Sep 22, 2008 08:59 PM
jdblazer
Jun 1, 2007 09:27 AM
