radiator
Old Jun 16, 2008 | 09:50 PM
freonchill's Avatar
freonchill is an unknown quantity at this point
Default radiator
shop said my radiator had crack in bottom
i checked online and noticed that aluminum core with plastic body
is there good silicone or epoxy that i could apply to the outside bottom of the radiator to help "plug the leak" - i figure i would need one that could deal with the heat.
thanks
Old Jun 18, 2008 | 09:46 PM
freonchill's Avatar
Default RE: radiator
bump
i know the forum is messed up (hard to post sometimes)
but if someone is out there, please just say a name of epoxy or silicone
ty
Old Jun 19, 2008 | 06:31 AM
Tried to reply the same day you posted, but got errors.
New radiator is my recommendation. If the crack is ONLY on the plastic tank, then you *may* be able to clean it up, rough it up, then seal it with some epoxy (something that will work on a fiber filled thermo plastic). I wouldn't trust it as the tanks go through a bit of thermal expansion.
Old Jun 19, 2008 | 12:24 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
I have a PERFECT factory radiator, out of my totalled (rear ended) 1998 Jimmy.
What's it worth, guys? $200? I really have no idea.
Old Jun 19, 2008 | 12:32 PM
Considering that a new aftermarket radiator is between $120 & $200 and that a new factory piece through GMPartsDirect.com is $240, I would think that somewhere around $150 shouldn't be out of the question for a good used part. I'm not trying to steal a sale, but I do know that I would pay FAR less than that for a used OEM piece from my local Pick-n-Pull yard.
Old Jun 20, 2008 | 12:40 PM
dBsound's Avatar
Then $150 it is, plus $20 shipping to lower 48 US(or pickup in Bloomington, IN).
Any takers?
dbsound@bluemarble.net
bigdaddykane93
Jan 4, 2010 12:03 PM
FLcruising
Jul 4, 2005 02:51 PM
Blazin 4x4
May 25, 2005 01:57 AM
PawNtheSandman
May 2, 2005 11:15 PM
93blazerman
Engine & Internal
Apr 7, 2005 02:26 PM
