radio
Old Oct 26, 2007 | 07:23 PM
rjskriba's Avatar
rjskriba is an unknown quantity at this point
Default radio
I need to remove the radio from my 95 s10 blazer ,the problem is the trim panel. how how do I remove the trim around the steering column? I have the trim poped off the clips but canot get it off round the column.it has a tilt wheel and the shifter handel is stopping me from removeing the trim piece. .am I doing something wrong? I have the radio ready to remove ,just need that panel out of the way
Old Oct 26, 2007 | 08:03 PM
hillbillyinOhio's Avatar
Default RE: radio
ok, first, drop the column all the way down. then turn your key forward and put the car in 1st gear. then turn the car back off. then carefully flex the center part (over column) over the hazard switch.
Old Oct 26, 2007 | 08:43 PM
rjskriba's Avatar
Default RE: radio
I tried what you told me How much will that piece flex? I feel like I coud break or crack something I have most of the wire connectios removed even removed two screws below the column on the panel below anyway thanks for the help maybe tomorrw will go better for me
Old Oct 26, 2007 | 10:48 PM
Default RE: radio
it will flex quite a bit. worse case scenario, drop off the under dash knee bolster and remove the 4 10 mm bolts holding the column up. then you are golden..!!
Boiler20
Oct 19, 2013 03:53 PM
dan_t
Nov 25, 2010 08:35 PM
iamchevyman5
Nov 7, 2010 01:20 AM
black19
Jun 22, 2006 03:35 PM
