Ran out of gas with 1/4 tank left????
Old Apr 9, 2011 | 04:08 PM
duncanidahoe's Avatar
duncanidahoe is on a distinguished road
Default Ran out of gas with 1/4 tank left????
Driving to work the other day and my blazer just quit dead. Cranked and cranked and it wouldn't start. So I had it towed to the place where I bought it to have them look it over all he did was add fuel to it and it started. Pissed me off because he ran it enough that when I left I made it about 50 yards and it ran out of gas again, luckily it was across from a convenience store so I walked across the street and paid $9 for a leaky 1 gallon gas can and then $3.65 for the gas. Poured it into the tank half of which went on the ground the can leaked so bad. Started the truck and went in for a fill up. The pump kicked off at 15 gallons and the tank wouldn't take any more, the gauge had said I had a 1/4 tank and apparently it was right. So my question is, is there something loose or replaceable that I can fix when I pull the tank so that it will pickup that last 5 gallons of fuel or do I have to fill up every time it gets below half a tank to be safe?
Sorry it's a 1999 Blazer 4wd. I have checked the fuel pump pressure and it checked out. Is there a fuel pickup hose or a filter on the fuel pickup that could be clogged? My Dakota had a filter in the tank as well as on the frame in the fuel line.
Last edited by duncanidahoe; Apr 10, 2011 at 06:21 AM. Reason: Adding vehicle info.
Old Apr 9, 2011 | 05:45 PM
84BlazerS10's Avatar
Your best bet is to keep your tank above half to keep your gas pump submerged in gas but your problems might be due to a weak fuel pump.
Old Apr 9, 2011 | 06:02 PM
jsegs01's Avatar
jsegs01 is on a distinguished road
I had the same problem happen to me and I kept mine above half a tank all the time. That was until the fuel pump died then I just replaced the whole fuel pump system and haven't had a problem since. now when it reaches about quarter of a tank I fill up so I dont get stranded
Old Apr 9, 2011 | 09:28 PM
racsan's Avatar
racsan is on a distinguished road
dad has had that issue with at least 2 of his 4 blazers, started filling up at every 200 miles on the tripmeter rather than trusting the fuel guage. i di think it was rather funny when i had to go rescue him, i would have thought it would have been the other way around. although the 2nd time it happend to him, he was on the way to fill up and was about 5 miles from the gas station.
Old Apr 9, 2011 | 10:25 PM
rriddle3's Avatar
It sounds like fuel starvation. Could be a bad pump (my guess) or clogged fuel filter or both.
Old Apr 10, 2011 | 12:51 PM
stlwaco's Avatar
stlwaco is on a distinguished road
When mine is on E it takes 15 gallons to fill up. Maybe your fuel level sender is sticking in the tank.
Old Apr 11, 2011 | 08:08 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
When the blazer reads 1/2 tank I have about 1/4 tank left. I never let it get far below there. It's better for the fuel pump to leave more fuel in it anyway.
Old May 9, 2011 | 01:47 PM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
Same problem, but with a brand new pump (yes, it's an AC/Delco - and a new fuel filter and pressure regulator as well)...it was working fine before installing the new pump. I was wondering if a new pump had to be "calibrated" to the truck. The reason I thought of this was that when I had a new heater vent door actuator installed, there was a calibration step so the BCM could operate it correctly.
Old May 13, 2011 | 10:16 PM
toaks1's Avatar
toaks1 is on a distinguished road
I have the same problem with mine ...
The issue is that you probably have a 2 door blazer fuel pump in your 4 door blazer. The 2 doors have a 15 gallon tank which is not as deep as the 18 gallon on the 4 door. The pumps are identical with the exception of the length (due to the different depths of the tanks) so the 2 door will fit into the 4 door tank but it wont pick up the fuel at the bottom because it is too short.
Smc
Nov 14, 2013 04:46 PM
Hooterville
18
Jan 31, 2013 09:38 PM
Anthony Archer
Jul 6, 2012 06:36 PM
lloyddavid
Oct 25, 2011 04:54 PM
wjdjake
Jul 17, 2011 02:06 AM
