random cylinder misfire
Old Nov 30, 2008 | 12:08 PM
Way Cool Jr.'s Avatar
Way Cool Jr. is an unknown quantity at this point
Default RE: random cylinder misfire
I have a 95 with the exact same problem right to the T have replaced almost every sensor last weekend i did the map, and IAC and it ran like a millian bucks for about a 3 1/2 hour road trip but as soon as i filled with gas it started doing it agine and has sense have ran injector cleaner thru it many times hope someone replies with a solution for us gonna look into haveing the injectors cleaned oo and my code says that its running rich on bank 1 but otherwise identical problem
Old Nov 30, 2008 | 08:17 PM
blazin8556's Avatar
blazin8556 is an unknown quantity at this point
mine is starting to point at the transmission. not sure if thats what it is or if thats whats wrong with everyone elses. but seems to me mine is haveing a problem with some kind of solenoid in the trans. got somewhere i could run it good. got it up to 95 mph. (i was impressed with how it did being a really old small suv) on the way home the truck ran excellent, shifted and ran smooth just like it did when i got it. next day it really stuggled and jerked. only did it on the way to the next town in the morning. then it was fine again. i am really starting to hate my truck. i want a ford, lol.
Old Dec 2, 2008 | 07:08 AM
blazin8556's Avatar
i bought a 3 step professional fuel system cleaner for 20 bucks at autozone. sprayed the throttle body out, and let the manifold suck up step 2 as directed and put step 3 in the gas tank as directed. will see if mine stops jerking. currently its really really responsive.
Old Dec 2, 2008 | 07:19 AM
punxweb's Avatar
punxweb is an unknown quantity at this point
I recently threw this code on a new motor. I replaced my injection spider with the updated design. You can get the spider with all new injectors, gaskets, and bracket for about $310 from Rockauto. It really smoothed the motor out. I always felt like the motor had a little miss since 5 years ago. Since I replaced the spider, this thing is golden. The part is a AC Delco, well worth it!
Old Dec 10, 2008 | 08:25 PM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
I'm glad I don't have a one-of-a-kind problem so maybe someone will have fixed this problem with their blazer and could tell us what to do. I've successfully stopped the misfire as of now. It's a really easy fix. Park the piece of crap. That's what I've done. I have maybe put ten miles on my blazer in the past month. I guess I'm gonna wait till I get the money saved up and take it to a dealership and get it fixed then sell it and go straight toyota. I've given up. I've been told it might be the fuel pump and a guy in town said his suburban did the same thing until he replaced the fuel pump. I don't know...I really don't feel like messing with this anymore. I'm not spending money unless it actually fixes this crapper.
Old Dec 10, 2008 | 09:02 PM
nimrodcs's Avatar
nimrodcs is an unknown quantity at this point
Default I had the same problem....
My 2001 Blazer had the same missfire problem. I changed everything that you did (plugs, wires, dist cap, rotor, ICM, etc) with no luck. It turned out that my intake manifold gasket, which is a common problem among 4.3's, had failed severely allowing coolant to get inside my cylinder heads.This in turn, rusted 3 ofmy exhuast valves so bad thatat low speeds/acceleration, I had horrible missfires. After a complete valve job on both heads ($99 at O'Reilly's Machine Shop) my missfires are gone and no troubles since.
Hope this helps! Good luck.
Old Dec 11, 2008 | 09:36 PM
1badblaze's Avatar
1badblaze is an unknown quantity at this point
Default RE: I had the same problem....
when diagnosing a misfire it is helpful to do a compresion tes on the engine when it is hot. everything was replaced on mine from injection spiders to fuel pumps to igntion coils etc. turns out that 95 model years have bronze guides in the heads and they were worn so bad that the valves wouldnt seat and in turn cause a miss. and it didnt show up untill i sucked a can of seafoam thru the brake booster hose. so before throwing parts do a compresion test fix any other codes po171 etc. a bank running rich will have a rich miss. same with a lean cylinder it will have a lean miss.
Old Dec 14, 2008 | 12:36 AM
ahnermark_1's Avatar
ahnermark_1 is an unknown quantity at this point
I have same proplem we all seem to have. replaced cap ,rotor,wires and plugs. same problem. have not checked compression or manifold gasket yet. But my mpg has gone from 15 to 10.do you think that points to the spider mfi being the culprit?
Old Dec 14, 2008 | 10:42 PM
trevorus's Avatar
trevorus is an unknown quantity at this point
A couple things to check. I have a 98 Blazer that had the same problem soon after I bought it. I went around changing and fixing a lot of stuff, and found out it was my spark plugs. The GM 4.3 V6 does NOT like regular resistor plugs. Platinum only on these engines, as in AC Delco Single Platinums. I did also replace the injector spider assembly, and it cost me less than 200 bucks or so when I ordered from GMPartsDirect.com. You have to know the right part number though. The new injector system gets rid of those crappy poppet valves, and replaces them with real injectors at the intake, rather than at the connector assembly. You also get a new fuel regulator, bracket, and gasket with the kit. I'll see if I can find the part number for it...
Old Dec 23, 2008 | 03:07 PM
Taurus24/7's Avatar
Taurus24/7 is an unknown quantity at this point
I had the same misfire at highway/cruse speeds. Mine turned out to be a bad distributor gear. The gear was half gone, each tooth was razor sharp on the end! Replaced the distributor and no misfire.
mbar
Nov 10, 2010 02:39 PM
hunterman18
13
Jun 22, 2010 07:55 AM
jashav
Mar 20, 2010 03:30 PM
Sk8Jitsu
Aug 16, 2009 02:16 PM
wicki5420
Aug 16, 2008 09:31 PM
