random missfire
Old Jul 17, 2011 | 11:48 PM
tim68's Avatar
tim68 is on a distinguished road
Default random missfire
I have a 02 blazer with a 4.3 , 2wd. My problem is i have a misfire just when it idles with the a/c off sometimes it will make the check engine light flash. and its worse at times. But when i run the a/c it runs fine no check engine light idles smooth. i have changed intake gasket, new distributer, plugs, wires, fuel preasure reg, crankshaft sensor. any suggestions
Old Jul 18, 2011 | 06:50 AM
A flashing CEL means that the PCM has detected a potentially harmful misfire. Have a read through THIS THREAD. Are there any other codes present/pending in the PCM?
What brand parts were used? Aftermarket caps & rotors have been found to not work correctly out of the box for many members.
What made you replace the CKP sensor?
Did you set the CMP retard after the new distributor was installed? With the setup of the ignition system used in these trucks, for accurate spark control & to extend the life of the distributor drive gear, CMP retard must be set to zero degrees using a scantool to monitor the value while you move the distributor in the hole through the lower intake manifold.
Have you done a CASE relearn? A CASE relearn or crankshaft variation learn procedure sets the precise variance between the actual ignition events and the readings from the CMP & CKP sensor readings. When replacing any one of the components that would affect this variance, a CASE relearn should be performed; especially if either the P1345 code is present or a misfire is present.
jcc0510
Mar 2, 2015 05:38 PM
professax
May 3, 2014 02:31 AM
KidBlazer
Feb 7, 2013 11:08 AM
crey 95 Blazre
Jan 6, 2008 07:41 PM
thefox1
Apr 9, 2005 07:30 PM
