Random vacuum line with bolt in end?
Old Apr 8, 2016 | 08:51 PM
Kphill95's Avatar
Kphill95 is on a distinguished road
Default Random vacuum line with bolt in end?
My 2000 Chevy blazer has a random vacuum hose coming out of the engine with a bolt in it. This line also has a check valve in it. Every post I have looked at hasn't shown it. Can anybody help please!?
Old Apr 9, 2016 | 12:00 AM
AJBert's Avatar
Pics would help to identify the line, or at the very least a description of where the line comes off the block.
Old Apr 9, 2016 | 01:24 AM
Kphill95's Avatar
Right around the pcv valve on the drivers side it connects to a check valve t. From that check valve T, it either runs to the drivers side panel, or it runs to this bolt. If that makes any sense. I'm a new member so I'm not sure how to post pics yet otherwise I would.
Old Apr 9, 2016 | 03:40 AM
newguy's Avatar
probably connects to the vacuum ball in the drivers side fender. connection is under the abs module
Old Apr 9, 2016 | 06:36 AM
Kphill95's Avatar
Those connections are in place. This one is closer to the Throttle body. Will try to add pics soon
Old Apr 9, 2016 | 06:51 AM
Kphill95's Avatar
[IMG][/IMG]
This is it.
Old Apr 9, 2016 | 07:18 AM
Kphill95's Avatar
This is the diagram I made from what I saw.
[IMG] screenshot tool[/IMG]
Old Apr 9, 2016 | 08:51 AM
newguy's Avatar
Thinking its a vacuum line for the 4 wheel drive or hvac. Does your 4 wheel drive work or do your heat vents change. Floor/defrost/interior?
Old Apr 9, 2016 | 08:56 AM
newguy's Avatar
Attached Thumbnails Random vacuum line with bolt in end?-2013-01-23_033936_blazer_vacuum_lines.jpg
Old Apr 9, 2016 | 09:40 AM
Kphill95's Avatar
4 wheel drive works. Heat works but softly blows even when turned off. Random spurts of cool air sometimes
