rattle in front end on rough roads
Old Jun 27, 2010 | 10:29 AM
walleye seeker's Avatar
walleye seeker is on a distinguished road
Originally Posted by CTYankee
My 2003 Blazer LS has a rattle that seems to be coming from behind the dash near the blower motor maybe. Had 2 different mechanics look at it as well as myself pulling everything apart, but just can't seem to find what is causing it. Doesn't seem to be anything important, so just turn up the music and wait for whatever it is to fail
It has been there for almost 2 years now.
That is what mine was doing but i found the rattle the hood hinges get wore and loose allows the hood to shake and rattle.
Easy fix i just stuffed a rag under each hing with hood open so when you close it up it will put tension on the hings. Presto rattle went away .
I have fixed every rattle in it silicone works great in the spots like plastic molding that may be rattling remove molding put a few dabs here n there reinstall fixed.
Old Jun 27, 2010 | 08:05 PM
CTYankee's Avatar
CTYankee is on a distinguished road
Sounds like a place we didn't check, hopefully it is the most obviuos, but also the most overlooked place Will try the rags under the hood near the hinges and see if the sound stops.
Old Jun 27, 2010 | 11:12 PM
4x4blazerguy's Avatar
Check your hood bolts. I had a similar problem that took me a year to find. It turned out to be the R/S hood bolt was loose.
Old Jun 29, 2010 | 09:26 PM
dagda's Avatar
dagda is on a distinguished road
Originally Posted by cage47
On mine my calipers rattle on the slide bolts. Sounds really bad but it's not a problem. Does your problem go away when you brake?
Mine does the same thing.
Old Jun 30, 2010 | 08:55 AM
CTYankee's Avatar
Seems that is what it was, the hood bolts/mounting bracket they go through are worn out. Had a piece of foam stuffed under there the past two days, as walleye recommended, and no more noise from that area! With the foam in there you can see how the passenger side is out of alignment and off. Going to replace them today or tomorow, thanks for the sugestions and help
Old Jul 6, 2010 | 09:35 PM
chevy ll man's Avatar
chevy ll man is on a distinguished road
Talking
it might be hood hinge bolts rattling i know it sound crazy but it drove me nuts check hinge bolts if their is a gap then you need to put at least 1 washer on the shoulder side of the bolt on both sides try that
Old Jul 9, 2010 | 07:33 PM
blazinloud's Avatar
thats my problem, and yes goes away when braking. its been months and i think ive finally figured it out. spent HOURS underneath testing everything. so your saying it wont harm rotors or wheel bearings?
Old Jul 9, 2010 | 10:52 PM
Flatearthman's Avatar
Flatearthman is on a distinguished road
2000 trailblazer its a GM thing once you get rid of one noise 3 others pop up.
meatbag
Sep 24, 2012 10:26 PM
fishinhunter12391
Oct 9, 2008 05:22 PM
portcqb
Apr 8, 2008 02:25 PM
drperry
May 11, 2007 03:56 AM
bat119
Sep 26, 2006 09:59 PM
