Rattle/vibration in drive with break applied
Old Jun 14, 2009 | 02:58 PM
Denominator's Avatar
Denominator is on a distinguished road
Default Rattle/vibration in drive with break applied
When I hold the blazer at a stand-still in any gear (R, OD, D, 2, 1) with the break applied I can hear a rattling vibration noise from under the car. It sound like it comes from under the passenger seat area but under the car. It's not there when I put it in park. And goes away when I start driving. Any suggestions on what this is? Something loose maybe?
Old Jun 15, 2009 | 03:37 PM
Got it figured out! My catalytic converter was loose! The joint against the muffler was very loose and needed tightening!
Old Jun 15, 2009 | 04:33 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
good to hear it was something simple.
Old Dec 20, 2009 | 07:41 AM
brian400ex's Avatar
brian400ex is on a distinguished road
Mine is doing the exact same thing. Its not really a metal to metal noise though. was yours?
Old Dec 20, 2009 | 10:00 AM
TFisher's Avatar
Banned
TFisher is on a distinguished road
Mine was making a funny non-metallic rattle and my cat was cracked. If you can't find anything on the outside making the sound, bang on the heat shield with something and listen for a rattle. If that happens, then you need a new cat.
You can go ahead and ignore it for about two years, but the chunks will eventually plug it and then you'll really be in trouble.
When it really gets bad, all sorts of weird stuff will happen, first you'll notice that the shift points go WAY up and there is no power to ever get to them, then when it's totally plugged, there will be a hiss and a banging rattle at WOT and you'll be able to go about 40 up a hill if you floor it, but see no symptoms below 3K. Won't throw a CEL either!
It's real fun to have that when the only merge ramp in town is a short one!
Hope this helps!
Regards,
Thomas
Old Dec 21, 2009 | 11:20 AM
brian400ex's Avatar
sounds like its in the dash though.
jmac219
Oct 6, 2021 09:49 AM
meatbag
Sep 24, 2012 10:26 PM
KK808
Apr 13, 2009 08:07 PM
Suspension Plus
Dec 17, 2008 01:54 PM
BradsBlazer
Sep 3, 2007 09:52 PM
