Rattle when accelerating!
I bought my 2001 Blazer Lt with 40,000k about six years ago. It's always had this weird rattle which seems to me to be and engine issue because it only happens when accelerating(no performance issues). Doesn't matter if the acceleration is fast or slow. It sounds like its comming from the the heater vents. I have read a few post stating it could be some loose clips in the venting system, but since it only happens when accelerating it doesn't make sense. I have already checked the pcv valve and that is working fine. Another post mentioned something about 99-01 blazers having some sort of air valves, which are metal covered by rubber boots. Not sure what that is, if anything. Any ideas would be greatly appreciated, as I am pulling my hair out in frustration!
Thanks,
Jason
Thanks,
Jason
it wasn't necessarily a rattle but it sure as hell caused alot of rattles, but it happened during acceleration, and not just normal coasting...i guess his could just be a u joint beginning to go bad?
Thanks for the ideas guys, checked out the cat and the exhaust and everything looks snug. Looks to me like plenty of clearence. The rattle is really hard to explain, it does sound like a heat shield or broken honeycomb in the cat. Not to long ago I bought a new muffler and all the pipe leaving it. The cat is actually the same one that was on when I bought the truck. My question is would it sound like its comming from the dash vents??? Really stange, mild boggling! I also recently noticed a gas smell when I get out of the truck, could it be a spark knock??? I've never heard one before.
