re: Mass Airflow Sensor
Hi there, I was wondering if someone can help me out. My mass airflow sensor keeps going off, now I took the MAS apart and cleaned iit properly with electrical contact cleaner and it seems to be working fine but my engine light is still on. I was informed if you discoonect the battery (negative side) this will reset the computer on the vehicle, which I did, but my engine light still stayed on...doesn't disconnecting the negative side reset the computer?
Is there any other way to reset it with paying $100+ for a diagnostics scan...
Anyinfo.be appreciated... thanks
ps. this is the second time I had to take apart my MASand re-clean it in weeks, after doing some more research I didn't relaize the K&N filter had to be abolsutely dry and oil free (via shop vac)before putting back in or may cause the sensor/engine light to go off again as the oil may end up on the clean sensor picking up dirt all over again
ZR 2
ZR 2
abadinalbany
Jun 25, 2009 03:52 PM
