re: Mass Airflow Sensor
Old Jun 22, 2008 | 09:32 AM
ZR 2's Avatar
ZR 2 is an unknown quantity at this point
Default re: Mass Airflow Sensor
Hi there, I was wondering if someone can help me out. My mass airflow sensor keeps going off, now I took the MAS apart and cleaned iit properly with electrical contact cleaner and it seems to be working fine but my engine light is still on. I was informed if you discoonect the battery (negative side) this will reset the computer on the vehicle, which I did, but my engine light still stayed on...doesn't disconnecting the negative side reset the computer?
Is there any other way to reset it with paying $100+ for a diagnostics scan...
Anyinfo.be appreciated... thanks
ps. this is the second time I had to take apart my MASand re-clean it in weeks, after doing some more research I didn't relaize the K&N filter had to be abolsutely dry and oil free (via shop vac)before putting back in or may cause the sensor/engine light to go off again as the oil may end up on the clean sensor picking up dirt all over again
ZR 2
Old Jun 22, 2008 | 10:04 AM
dBsound's Avatar
dBsound is an unknown quantity at this point
Default RE: re: Mass Airflow Sensor
Go to Advance Auto. They'll reset it for free, and print out the codes for you.
Old Jun 22, 2008 | 02:40 PM
^^ Yep ^^ Let us know what the codes are.
Old Jun 23, 2008 | 11:49 AM
ZR 2's Avatar
I'm from Toronto...
Old Jun 23, 2008 | 01:57 PM
cliro's Avatar
cliro is an unknown quantity at this point
autovalue does it in canada
idezire
Nov 3, 2011 05:31 PM
abadinalbany
Jun 25, 2009 03:52 PM
EuroGoldLS
Headers, Intake, & Exhaust
Mar 25, 2007 01:33 PM
ilikebread
21
Mar 29, 2006 11:30 PM
BlaZeR FXB1581
Nov 13, 2005 03:41 PM
