Rear Axle Vent Question
Old Sep 25, 2020 | 09:56 AM
kmenc67's Avatar
kmenc67 is on a distinguished road
Default Rear Axle Vent Question
I just noticed the rear axle vent tube has become detached on my 2003 2Dr Blazer ZR2 and that the vent nozzle it attaches to has become significantly corroded. Is that nozzle replaceable? I've been unable to determine if it is a screw-in nozzle or is permanently built into the axle housing.
Old Sep 25, 2020 | 06:14 PM
LesMyer's Avatar
Should be a press-in fitting. P/N 26062696 at your local GM dealer or Ebay. Drive it in with a deep socket that will clear the nipple.
Old Sep 25, 2020 | 07:34 PM
kmenc67's Avatar
Thanks. Unfortunately every source I look at indicates that part number isn't compatible with models after 99. I cant find it on diagrams for the 2003 rear axle/diff though.
Old Sep 26, 2020 | 05:17 AM
daveca's Avatar
Better check to see if WATER got in the diff. "Corroded" means WATER...
Old Sep 26, 2020 | 08:52 AM
LesMyer's Avatar
Part #39 - if still in doubt have your dealer parts guys look it up.
https://www.wholesalegmpartsonline.c...category=19396
This product fits 483 vehicle variants.
Buick: 1 models, 4 variants between 2004 and 2007.
Chevrolet: 40 models, 400 variants between 1982 and 2012.
GMC: 5 models, 57 variants between 1985 and 1999.
Hummer: 1 models, 5 variants between 2006 and 2010.
Oldsmobile: 1 models, 17 variants between 1991 and 2006.
Old Sep 26, 2020 | 10:14 PM
kmenc67's Avatar
OK cool. Thanks very much for your help. Now I just have to figure out how to remove the remnants of the old one without having to take apart the whole rear end.
Old Sep 26, 2020 | 11:05 PM
LesMyer's Avatar
probably an "easy out" will work best if there is a metal ring left inside of the hole in the housing from a broken-off fitting. I wouldn't push it in.
Good luck.
Old Sep 27, 2020 | 12:06 PM
Good luck.
You also might be able to tap the inside of the broken piece, then use a bolt with a washer and a socket to pull it out. Use grease on the tap to avoid getting shavings in the housing.
Old Oct 21, 2020 | 05:09 PM
kmenc67's Avatar
yeah I'm planning to go ahead and flush and refill the differential just to be safe.
Shawn Kelley
Aug 11, 2017 10:21 AM
TMM217
Oct 18, 2015 03:41 PM
W2JGA
Jan 20, 2009 05:31 PM
non blazing 4x4
Dec 9, 2007 10:00 AM
walkingtall
Oct 30, 2006 01:12 PM
