Rear brake line replacement
Old Jun 5, 2011 | 11:48 AM
Fusefinder's Avatar
Fusefinder is on a distinguished road
Default Rear brake line replacement
I am planning on replacing the rear brake line (I have a rusted line that brew out) I plan to replace from the coupler as close to the master cylinder/ABS module as possible to the furthest back coupler.
I have 2 questions:
1) I was planning on using steel lines. Do I need a Double flare tool or a Bubble flare tool?
2) Is there another option rather than the steel line replacement that is better or easier?
Thanks
**EDIT**
By the way I am working on a 1998 Chevy Blazer 4.3l engine 4dr 4wd with ABS
Last edited by Fusefinder; Jun 5, 2011 at 12:05 PM. Reason: Vehicle description added
Old Jun 5, 2011 | 12:03 PM
hubert hefner's Avatar
hubert hefner is on a distinguished road
1. i would use the double flare.
2. the brake lines they use these days you can bend by hand without kinking them pretty easily.(they are kinda a grayish green color.)
Old Jun 6, 2011 | 07:42 PM
abig84's Avatar
you shouldnt need any flaring tool, if you just buy the exact length lines and use connectors. BUT you said your going from the abs unit. i did all metal brake lines the other day on i believe a 95 tahoe. and it uses the common 3/16ths for front but every end that went to the abs unit was bigger so i did have to cut and reflare every line, sucked.
ComputerNerdBD
Dec 14, 2014 05:43 AM
elkram
May 28, 2013 05:34 PM
midnightbluS10
May 19, 2013 11:12 AM
bugsbunny16374
Feb 27, 2011 08:06 AM
raileyp08
Jan 18, 2011 05:27 AM
