rear brake problem
Old Jun 15, 2010 | 10:50 AM
99 blazer's Avatar
99 blazer is on a distinguished road
Default rear brake problem
they wont release a the way and sqeeking a little..and burning them up..there brand new pad and the rotors and calipers were replaced last time..what could it be? this happened last time and i replaced the calipers and all was good
Old Jun 15, 2010 | 04:00 PM
84BlazerS10's Avatar
My car did this for a while, found out the emergency brake cable was rusted out and wasn't releasing the brakes all the way when you pulled it.
Old Jun 15, 2010 | 04:21 PM
warthogdriver's Avatar
are the pads sliding freely on the caliber....i found that autozone brake pads most times need a little massaging with a file to make them move freely.
Old Jun 16, 2010 | 12:09 AM
99 blazer's Avatar
what do you mean? cause there autozone pads..lol
Old Jun 16, 2010 | 04:29 AM
i mean the metal portion of the pad where it rests on the rail of the caliber, i have had them be so tight that i needed to file them to fit properly.
if they cant move freely on the rail they will bind up and ruin the pad, rotor, or worse.
and yet i continue to buy them.....damn you autozone points!!!!!!!!!!!
Old Jun 16, 2010 | 08:18 AM
Frankiesurf's Avatar
Frankiesurf is on a distinguished road
That sounds logical. If it is both sides I would look into that. If just one side maybe you need a brake hose. You can't tell from the outside if they are bad, they collapse on the inside and restrict fluid flow.
Old Jun 16, 2010 | 10:14 AM
99 blazer's Avatar
the right side is a little worse but both are doing it.and I dont think its the hose cause they worked fine right before i swapped the pads..
Old Jun 16, 2010 | 11:32 AM
Audihoe's Avatar
Audihoe is on a distinguished road
Make sure you can slide the pads on and off by hand with ease from the caliper bracket. If they are too tight you'll have that problem. I so, make sure surface rust if off the bracket using a file/sand paper. Dont go crazy or they will be too loose and slam around when braking.
If the wheel is tight like the brakes are held on without the pedal down, crack the bleeder. If they free up you may have a hose problem.
Old Jun 16, 2010 | 12:14 PM
99 blazer's Avatar
i think its the pads being too tight..im takin them back now(there a little burnt) thanks for the help ill let you know with the new ones
mkm1387
Jul 30, 2012 11:37 PM
bill737
Jun 24, 2011 04:24 PM
hcii
Nov 3, 2010 08:30 AM
gscrippler
May 14, 2010 06:23 AM
mlon01
Sep 7, 2007 11:48 AM
